The ERPS ring could not be enabled. The specific reason will be included in the log message.
The reason identified in the log will describe, in sufficient detail, why the ring could not be enabled. Please correct the error condition, and then, issue the CLI command "enable ring [ring-name]" again.
Error
Failed to enable ring %ring% during load config. %reason%
| Name | Type |
| ring | String |
| reason | String |
